94 accord won't rev past 2k
Old Sep 19, 2012 | 07:52 PM
Slidesquad240's Avatar
Default 94 accord won't rev past 2k
Hey guys I just replaced my motor with a f22 from a 97 and finally getting it to run it idles rough and seems like a misfire it won't rev past 2000 rpm and it just bogs and stalls out? I heard something about the crank position sensor? Does that need to be bypassed and could this be my issue? Thanks for the help
Old Sep 20, 2012 | 03:49 PM
Any ideas?
Old Sep 20, 2012 | 05:23 PM
accord1224's Avatar
not enough info..
you could have a hundred places for problems with a newly installed engine. check wiring and connections. Check sensors for matching up with old engine. and so forth
Old Sep 20, 2012 | 05:36 PM
I don't have old engine I've checked all plugs numerous times only sensor that not hooked up is the crank position sensor. I replaced main relay because it wasn't starting fired up after that and now this issue
Old Sep 20, 2012 | 05:44 PM
The crank position sensor is part of the distributor housing on the 94 Accord; whereas, on the 97 the combined Crankshaft Position and TDC sensor is separate from the distributor housing. On the 97, it should be located just below the crankshaft, fastened to the oil pump housing.
Old Sep 20, 2012 | 08:28 PM
Yes thats where it is but mine isn't hooked up cuz its a 97 motor into a 94 so would it not being hooked up cause it to run like crap??
Old Sep 20, 2012 | 09:29 PM
Did you use the distributor from the 94 engine?
Old Sep 20, 2012 | 11:02 PM
Yea using the 94 distributor
Old Sep 20, 2012 | 11:09 PM
Were both motors F22B1 or F22B2?
Did you do any work on the new motor, like timing belt, tuneup, etc...?
Is the check engine light turning on while driving?
Old Sep 21, 2012 | 07:34 AM
Pretty sure they were different I haven't done a tune up yet and I can't even drive the car it won't rev enough to move its 5 speed also
