94 drivers side window motor
Old Feb 5, 2007 | 09:06 PM
adamc44's Avatar
Default 94 drivers side window motor
i just want get your opinions on what might be wrong with my drivers side window motor. when its warm out it goes down alright, but as it gets colder it wont go down but a few inches. the other windows work pretty well so im guessing the motor is just shot, just curious if anyone has ran into this problem. also, if it is the window motor, where is the best place to get a new one. thanks for your help
adam
Old Feb 6, 2007 | 01:00 AM
hondadude's Avatar
Default RE: 94 drivers side window motor
Try spraying the window run channel with silicone lube, and run the window up and down a few times spraying the run channel between each window cycle.The drive motor will stop if it feels an 'overload' and the run channels can create enough drag to cause this.
If you spray all the run channels at each oil service interval you'll have no problems.
Old Feb 10, 2007 | 10:45 PM
adamc44's Avatar
hey, just wanted to thank you for the tip, the drivers side window works great now, i went ahead and serviced the others as well.
thanks hondadude
adam
Old Feb 11, 2007 | 02:00 PM
accordfan's Avatar
can this lubrication be done with the door panel in-place, or do you have to remove it to get to the channels you talk about??
Old Feb 11, 2007 | 03:02 PM
hondadude's Avatar
No need to remove the door panel; the window run channel is the 'slot' the window runs in.
Roll the window down and spray the 'slot', then run the window up and down; the window will, so to speak "drag the lube" down the channel.
Michael Bomes
Sep 9, 2012 03:12 PM
Creepyjeeper
May 26, 2012 04:48 PM
shakinroch
Oct 1, 2008 09:39 AM
Jeffmo
Aug 15, 2007 07:56 PM
Major
Jun 2, 2007 06:10 AM
