94 EX Crank, no start, fuel pump not running
Old Feb 28, 2011 | 08:18 AM
wietgr's Avatar
Default 94 EX Crank, no start, fuel pump not running
1994 EX 2.2L VTEC MT 4DR - I have crank no start issue, when just turning key on i dont hear the pump running, engine will start and run on ether so Im sure its a fuel issue. I replaced the notorious relay a couple years ago, anyone have a copy of the wiring schematic for the fuel pump? Thanks in advance!
-Greg
Old Feb 28, 2011 | 05:04 PM
You can download a 94 shop manual from the hondatech link in the Online Manuals thread in the DIY section. That will have the wiring.
You will need to verify that the main relay is sending power to the fuel pump. There is an electrical connector in the trunk where you can test for 12V.
Old Feb 28, 2011 | 08:00 PM
wietgr's Avatar
thanks, i got the diagram and the test procedure from alldata im getting power at the connector in the trunk, i love how they give you access to the sender but not the pump, pull the tank earlier tonight gonna put the pump in first thing tommorrow
rockhoundrob
Apr 11, 2014 11:41 AM
Westjoe64
Oct 15, 2012 12:11 PM
tuabuelo
May 21, 2010 08:14 PM
sofireguy
Jun 27, 2009 01:12 AM
kissbally78
Jan 18, 2009 07:14 PM
