94 ex what's going on under the dash and with my dash
Old Jul 12, 2018 | 02:53 PM
Seanjordan20's Avatar
I see in your pics a br/y or bl/y cable that needs to be hooked back up. For some reason they have a yellow cable connecting them.
I also se a green dotted cable that needs to be connected to its other end.
Is that what you are talking about
Old Jul 12, 2018 | 02:54 PM
If you have not already. All that tape needs to come off to see what is going on
Old Jul 12, 2018 | 03:38 PM
Originally Posted by Duston
Ok so in the very last pic the 2 wires that are sticking out look like factory wires not aftermarket ones. Should I be concerned or do anything with those 2 wires?
Those are the lock input and unlock input wires that go to the power door lock control unit. Normally, there is a gray 2P connector with those wire located under the dash. There probably was an aftermarket alarm previously installed and they cut off the connector. You can cut the exposed ends off and tape them up.
Old Jul 12, 2018 | 04:06 PM
In the following photos, the Blu/Blk wire is most likely non-OE.
One piece was spliced into the OE Grn/Wht wire for the brake switch. Probably there was previously an aftermarket alarm/remote starter. Hooking up to the Grn/Wht wire is generally done to simulate the brake pedal being depressed to be able to start the car, by momentarily applying 12 volts to that circuit.
treypal
Feb 8, 2012 11:56 AM
Dead Bison
Apr 3, 2008 02:23 PM
markinchico43
Jan 20, 2008 08:34 PM
tiffany
Jan 31, 2007 11:52 PM
marky4
Sep 5, 2006 03:21 AM
