94 Honda Accord 300,000 miles
Old Jun 22, 2008 | 12:29 PM
gpro's Avatar
Default 94 Honda Accord 300,000 miles
I came to this site since my water pump started leaking and wanted to replace the water pump myself. This will be my first attempt to replace the water pump, timing belts and seals. I recently done my thermostat and felt good about the installation and then my water pump started leaking. I just bought the timing belt and water pump kit from ebay and looking to get this installed in the next few weeks.Wish me luck and if there is anything I should look out for before I attempt this let me know. Thanks and this forum is awesome.
ro
Old Jun 23, 2008 | 12:40 AM
Default RE: 94 Honda Accord 300,000 miles
Thank You for joining and Great Luck on that water pump install..
Old Jun 23, 2008 | 02:14 AM
You can download a shop manual for a 94 in chapters in the ACC 5th gen... thread in the DIY section. That will help a lot.
Read up on removing the cranshaft bolt. It is a major PIA loosen.
Also, use white-out to make your own marks on the old timing belt and on the teeth of the pulleys on the timing and balance belt. A second set of marks will help ensure that you have the new belt installed correctly. When I went to mark the new belt with white-out based off the old belt, I found that the new belt had an extra tooth. I ended up counting all the teeth on the belt to make sure that I wasn't losing my mind. I bought one from the honda dealership and it had the correct number of teeth.
Arm youself with as much information as possible when you tackle the job, and it will make the job go much smoother.
Old Jun 23, 2008 | 03:20 AM
YeuEmMaiMai's Avatar
my 94 is only 100K behind yours lol
Old Jun 23, 2008 | 01:02 PM
HondaPhyco's Avatar
300k OMG OMG! I wish my accord stays up that long. I will sure try.
Old Jul 10, 2008 | 12:10 PM
gpro's Avatar
I found this great write up with pictures from another forum. I hope it's not against the rule to post other links of other forum. Here it is:
http://www.honda-tech.com/zerothread?id=1908944
I hope it helps other people.
Old Aug 26, 2014 | 11:42 PM
gpro's Avatar
Default Update: 358000 miles
I still have the accord and currently at 358000 miles. I have came back to this forum since I have newly acquired a 97 V6 2.7L accord. Thanks to this forum, it help me keep my accord running strong. I'm not much of a poster but I have lurked since 2008.
Old Aug 30, 2014 | 05:10 AM
UhOh's Avatar
Holy thread resurrection GPRO! After 6 yrs.
Anyway, glad you're still there ... er, here.
Post up & help with issues as often as you can.
blahblahtown
Jan 27, 2011 09:58 PM
sarah7246
Jul 12, 2010 01:28 PM
inthedump
Aug 2, 2007 03:15 PM
Mar 6, 2007 08:27 PM
espn2829
Apr 15, 2006 11:54 AM
