'94 Honda accord ex FAILED smog test, HELP!
Old Jun 12, 2013 | 12:03 AM
torresusmc's Avatar
Unhappy '94 Honda accord ex FAILED smog test, HELP!
did not pass- "gross polluter"
- replaced spark plugs
- replaced egr valve
- cleaned out egr (under fuel lines)
the smog center guy said to take out head gasket and clean air ways from there OR replace the "cat" and air sensor.
I'm am a novice mechanic at best.
How do I remove the head gasket to get to the airways?
Should I replace the cat and air sensor?
I don't have a lot of money- which would be cheaper?
Old Jun 12, 2013 | 09:08 AM
Did you get more information from the test? Was CO high? Or NOx? What you might try, depends on how it failed.
Old Jun 12, 2013 | 05:28 PM
And to add to Jim's questions - what do you know about the normal tune up items (cap, rotor, plugs, air filter, pcv and inspect the wires)?
jsharp
Sep 24, 2013 12:45 PM
9DEX
Nov 5, 2011 10:21 PM
jayalaba
Oct 11, 2009 04:15 PM
micahjames
Mar 20, 2007 02:16 PM
jetblack3s
Nov 25, 2006 04:38 PM
