94 Honda Accord EX with Leaking Crossover Pipe
Old Aug 28, 2014 | 07:11 PM
EXMan's Avatar
Default 94 Honda Accord EX with Leaking Crossover Pipe
I am trying to replace the Connecting Pipe on my Honda with 296k miles on it. It is leaking at the O ring end where it goes into the water pump. I have done a search on this site and can't find anything on this topic. I understand this is a common problem as the pipe itself rusts out in addition to both o rings going bad. Here is a scemantic:
How do I remove this pipe? It is impossible to do it from above. The intake manifold and throttle intake is right in the way. On the throttle intake, there are several bolts that can be removed. However, the last bolt is wedged in against the firewall and impossible to remove. How do I do this job?
I found this video where this guy has the same car as mine (F22B1) and the same problem as I do. Start at 2:40.
Please help?
Old Aug 28, 2014 | 09:05 PM
I've done cylinder head which requires access to same area but does not remove xover pipe. I found following thread which may help.
Replacing the connecting pipe (thermostat to water pump) - Honda-Tech
jeepthing07
Mar 22, 2014 02:52 AM
cavemantitan
Jun 5, 2013 12:19 AM
goathead
Mar 19, 2011 01:15 PM
pablo13
Aug 28, 2006 10:20 PM
purify
Jul 7, 2006 07:35 PM
