94 honda accord ex A/T 2.2l vtec rough start
Old Jan 6, 2022 | 04:50 PM
Cofer1121's Avatar
Default 94 honda accord ex A/T 2.2l vtec rough start
I recently bought a 94 honda accord ex a/t 2.2l vtec (f22b1) grinding noise when starting some times like the start won't catch then will start cranking, fires up then dies, after 2-6 times trying to start it fires right up. The vehicle was sitting for about a year. Changed main relay, ignition switch, distributor, plugs, wires, pulled started got it tested it check out good. Throws a code 9 after new dizzy. The seller said he put a new fuel pump in I'm just scratching my head any ideas what it could be??
Also just learned it has a clifford alarm with remote start, seems to start up fine with the remote now I'm really confused
Old Jan 6, 2022 | 07:10 PM
Alarm systems that are not installed properly or have an internal issue can cause some strange starting problems. Take a look at how the alarm system is wired for any obvious signs of poor connections. I remember years ago someone opened up the alarm control unit and found a burnt resistor that caused all the problems.
You may want to search the web for common problems with your specific clifford alarm system to see if there is a DIY fix out there.
For the code 9, is the check engine light flashing 9 times or the D4 light (if you have an automatic transmission)?
Old Jan 6, 2022 | 08:00 PM
Cofer1121's Avatar
cel flashing 9 times it has a new timing belt and the timing lines up checked it with a timing light and it is a automatic transmission d4 light flashes on rare occasions pull a code 14 off the d4 light but hasn't flashed in a while
Old Jan 6, 2022 | 10:16 PM
Cofer1121's Avatar
alright so I must be the aftermarket alarm that was installed on it when using the remote start(had to figure out how it worked) I have had no issues starting the car no CEL
Spmc662
Dec 22, 2021 04:30 PM
carfreak4
Jan 17, 2013 08:29 AM
xJDMxAccord
Jan 28, 2011 01:22 PM
MOPAR214
Jul 28, 2010 02:42 PM
zrooster99
Nov 12, 2007 05:04 PM
