94 Honda Accord LX - Stalling when idle/engine shaking hard
Old Jun 28, 2010 | 05:53 PM
Your problem could be the VSS or the speedometer.
When the speedometer isn't working, try to use the cruise control. If it works, the VSS is ok and your speedometer is bad. Mine would get stuck at ~19mph and the odometer wouldn't work. The cruise would work fine. It is a common problem. You can try remelting the solder joints on the speedometer board. You would have to remove the gauge cluster and remove the speedometer. I read this fix on another forum and it worked for someone on here.
A bad VSS will also turn on the check engine light. The D4 light would start flashing as well.
erader00
Aug 25, 2012 01:29 AM
mishakol129
Nov 12, 2011 03:32 PM
hondaac
Jan 13, 2009 01:30 PM
patrickr2018
Jan 26, 2008 11:29 AM
hopkinted
Dec 30, 2006 04:41 PM
