94 Stalling issue when operating temp
Just bought a 94 Accord. Im having an issue whenever slowing down for a stop that it stalls out, and then will restart right away sometimes and other times it will take a few minutes. Ive read a lot of threads with the exact problem and theyve replaced the EFI main relay, distributor components, fuel pumps, ECMs ect, and they are all still having the problem. I was wondering if anyone could shed some new light on this issue and tell me if theyve figured it out. Thanks for your help!
How many miles are on the maintenance items, like dist. cap, dist. rotor, and spark plugs.
I would also check for codes.
If the car always stalls out when coming to a stop, try putting the car in neutral, then come to a stop.
And to add to the check list from PA.....the IACV and FITV should get a good cleaning.....while there the TB should get one too....get both sides of the butterfly and be sure to get some cleaner into both "ports" on the back/firewall side of the tb.
Im planning on doing a full tune up this weekend (plugs, wires, cap and rotor) I have no idea how old they are. No codes popping up at all and if i put it in neutral and hit the gas slightly itll stay running.
Only use the NGK zfr5f-11 spark plugs that you can get at most parts stores for you car.
The OEM spark plug wires seem to last forever. If you want to replace them, I would get NGK or Denso spark plug wires as they are good quality.
I suggest OEM distributor cap and distributor rotor, but others one here have not had problems with the aftermarket parts.
one_lucky_monkey
Feb 9, 2021 11:11 PM
HighwayStar
Jun 15, 2015 10:18 PM
mastar91169
May 10, 2007 01:24 PM
