95 Accord blinkers blow fuse
Old Nov 15, 2007 | 04:09 PM
skowald
Default 95 Accord blinkers blow fuse
The 7.5A blinker fuse blowsintermittenly and the 15A hazard fuse seems to blow pretty regularly if used. I've taken out the frontlenses and checked thewiring at the lightsand also checked the wiring at the back lights and it looks ok. I've dug around under the dash some but have yet to tear into it any further. I'm hoping someone else has experienced a similiar issuewith this year model. I have a voltmeter handy if someone knows a good place to take some measurements. My niece purchased the car from a dealership (as is of course) and at that time the dealership hadthesteering column coverpulled off so there was probably an issuefrom the get go.
Thanks in advance.
Old Nov 15, 2007 | 04:13 PM
sir_nasty's Avatar
Default RE: 95 Accord blinkers blow fuse
either in the steering column or a bad ground, does all the wiring look stock?
Old Nov 15, 2007 | 04:36 PM
skowald
Thanks for the reply! The wiring all looks stock. (The dealershipgave herthe single owner little old lady speech.) I did check the wire terminal lugs at the fuse block under the hood to make sure theywere tight. One more note: A week or two after my 16 year old niece got the car she did break the front lens and damaged the fender slightly on the drivers side as shewas backing out of the church parking lot! The damage wasn't very badbut the repairplace wound up replacing theleft front fender and blinker/parking lightlens. When I had the lens outI looked to see ifnew fender wascrimping anything but didn't see anything.I suppose it could be.
Old Nov 15, 2007 | 04:57 PM
deserthonda's Avatar
I would look around at the area of the accident,( blinker lense , ) for a pinched wire or a bare power wire being grounded
if it blows a fuse ,you got a power wire shorting to ground
tvandentop
Sep 17, 2011 06:42 AM
Memphis465
Jul 1, 2011 06:46 PM
deathstalker
Sep 29, 2008 10:32 AM
Apr 3, 2007 03:45 PM
nwurts
Apr 9, 2005 12:56 AM
