95 accord code 3
Old Mar 3, 2013 | 03:57 PM
KelvinR's Avatar
Default 95 accord code 3
hey guys so I have a check engine light and im getting a code 3, and im getting a code 4 on the flashing d light. now my question is I just replaced the tranny should I take it back and tell them to.fix that code 4? which I read is a crankshaft position sensor.
or is that my problem? the tranny has a 1 year warranty
and what can I do about.the code 3? new map sensor?my rpms are jumping a bit and ice already my whole intake/throttle
Old Mar 3, 2013 | 04:07 PM
The CEL code 3 is for the map sensor. Start simple and check the electrical connector.
The D4 code 4 is for the lockup clutch not engaging (the D4 has a different set of codes). The shop should look into that one.
There is an important ground bolted to the thermostat housing that you may want to check. I would unbolt it and clean the eyelet with some sandpaper. The reattach it.
Old Mar 3, 2013 | 04:54 PM
KelvinR's Avatar
Thanks for the feedback, im going to check it out right now, this is important for the map sensor right? not the lock up clutch right?
Edit: Just looked for a ground on the thermostat and found none. btw this is a automatic tranny
Old Mar 3, 2013 | 10:59 PM
Sorry, thought you had a different generation accord. That important ground is on the top of the intake manifold on the driver's side of the manifold. Here is a picture:
Attached Thumbnails 95 accord code 3-pahonda-5547-albums-pics-2243-picture-g101-6236.jpg
Old Mar 4, 2013 | 03:24 PM
KelvinR's Avatar
hey thanks for the info. I have another question, are both crankshaft position sensors the same? the one infront and back?
Old Mar 4, 2013 | 04:36 PM
What do you mean both?? There's only one CKP sensor.
I think it's bundled together on the same wiring-harness plug along with the TDC sensor. So I guess YES they are different.
Old Mar 4, 2013 | 08:57 PM
KelvinR's Avatar
Oh god im sorry I was actually looking at the mainshaft speed sensor and the countershaft speed sensor . Where exactly is the ckp ?lol wow i fail
Old Mar 4, 2013 | 10:35 PM
They have different Honda part numbers, so they are not the same part.
The crank position sensor (CKP) is one of the three sensors in your distributor (it was moved to under the timing belt cover when OBD2 was introduced in the 96 accord). Each sensor in the distributor is the same, they each send different signals at different times to the computer per revolution of the engine.
Old Mar 5, 2013 | 06:40 AM
KelvinR's Avatar
do you think replacing the distributor will fix the problem?
Old Mar 5, 2013 | 09:45 AM
Speaking of fail, I should have paid more attention to the beginning of this thread. Then I would've known it was a 1995 car.
