95 accord ex 2.2 vtech with 179000 miles
Old Sep 21, 2011 | 07:17 PM
mljdd's Avatar
Default 95 accord ex 2.2 vtech with 179000 miles
My accord started running rough a few weeks ago only when in gear at at around 1700 to 2100rpm...if idling it fine. if you rev it up while it's in neutral it flutters a little around 2000 to 2500 RPM's. I replaced plugs, wires, and distributor cap with no luck. then a mechanic at honda thought it was the drive shaft so i replaced the right and left, and also new rotors. still no luck. seems like to me its more of a performance issue. it runs so rough at certain RPM's that the dashboard and steering wheel shakes pretty bad. Any help would be greatly appreciated. Thanks....Mike
Old Sep 21, 2011 | 07:59 PM
mljdd's Avatar
Default 95 accord running rough at certain RPM's
my accord seems to run really rough around 1700 to 2200 RPM's.
Old Sep 21, 2011 | 10:37 PM
Moved here to the correct forum for a question...
Old Sep 22, 2011 | 12:10 AM
In the common DIY thread on top of the gen tech help forum, there is a link for cleaning the EGR port for the 5th gen accord. I check out the links provided and clean the EGR ports. It should help eliminate the stumble in that rpm range.
localstoner
Oct 25, 2013 05:56 PM
firefunk
Nov 27, 2011 02:15 PM
92accordDX
May 3, 2008 08:57 AM
juanisa11
Oct 17, 2007 03:12 PM
bil6ly05
May 21, 2007 10:55 PM
