'95 Accord EX intermittant power interuption
Old Oct 24, 2011 | 03:37 PM
tbone's Avatar
Default '95 Accord EX intermittant power interuption
The power to the radio among other things cuts out for second then comes right back? Sometimes it does it out of the blue other times exactly when you dim the headlights. Also noticed the gauges bounced at the same time once. My son drives it so he sees the problem more than I have. I changed the cigarette lighter relay (which the radio power goes through) also changed the headlight relay & the dimmer relay. Any help would be appreciated.
Old Oct 24, 2011 | 05:25 PM
Shake the key while the engine is running. If that causes the electronics to act up, then you may need a new electrical portion of the ignition switch.
bailey9878
Jan 16, 2011 03:02 PM
djstylze
Jul 9, 2010 01:17 AM
cincyred5
Jun 23, 2009 07:00 AM
Rayman4449
May 14, 2008 11:29 PM
MHFry1
Dec 23, 2007 05:30 PM
