95 Accord Idle Issue
Old Oct 12, 2013 | 08:25 AM
Suggest trying to adjust idle air flow by disconnecting iacv electrically and adjusting bypass bleed screw to obtain about 550 rpm +/- 50 rpm. If turning the bleeder has no impact, the iacv passages are blocked somewhere.
Old Oct 16, 2013 | 04:27 PM
Mario Locatelli's Avatar
*UPDATE**
Was on my honeymoon so thats why the lul...Anyways, Ive changed the IAC and FITV..Upon changing them the idle issue was fixed it seem. When I would take it out of gear and put it into neutral the rpm's would go down like normal. But the next time I got in the car everything went back to the same problem. "Idle would climb when i put it in neutral and stay at around 2k rpm's...Then as im just about at a complete stop the rpm's would drop to around 500 and then raise up to around 700. What should i try next?
Old Oct 19, 2013 | 02:27 PM
Anyone?
Old Oct 19, 2013 | 03:32 PM
Post the wire colors going to the TPS, the MAP sensor, and the IACV.
Old Oct 20, 2013 | 08:36 AM
Suggest cleaning the throttle plate carefully, back and front. It may be sticking partially open, then going closed. This may have caused a misadjustment of base idle.
High idle indicates air leakage from somewhere. EGR sticking open, PCV sticking open.
Has base idle adjustment been performed?
Old Feb 9, 2014 | 08:10 PM
I know im reviving an old thread, but I finally got this issue fixed and just wanted to let it be known. I dont know why it was this issue, but it seems to have been. I just replaced my clutch and all the above idle issues are now gone.
I know its a last resort, but i never would of changed it if it hadnt gone out and i would of just lived with the issue.
Thanks to all who helped when you did
RWilliams
Jul 24, 2011 09:16 PM
dantegl36
Aug 28, 2007 09:33 AM
js593
Aug 13, 2007 11:52 AM
Tater516
Jan 31, 2007 11:07 PM
fperezal
Jun 14, 2006 05:03 AM
