95 Accord - Issues
Old May 7, 2012 | 01:13 AM
viequense's Avatar
Default 95 Accord - Issues
My car 1995 accord 2.2 v tec does the same thing.
Sometimes it runs great but u stop on a light and it starts with no power again, doing the whistle/vaccume sound
If i start driving the car withoiut leting it warm it runs great but when i stop and put it un parking it starts idlle up and down.
after the car is warm just sometimes runs good and u can feel it when u press down the acelerator
the rest of the time it takes to mouch to go from 0-60 cuz is like not having power.
Old May 7, 2012 | 07:05 PM
Moved, really should start you own thread.
Did/what testing have you done? Any in the thread this was at the end of?
Old May 7, 2012 | 08:26 PM
jroxz44's Avatar
Almost A Senior Member
My car is the same thing...... I tried eveything under the sun. For the first half hour it ran great then ran bad and lost alot of power.. A new fuel filter fixed everything for me. Try that and post back if it helps. But beware the incredible hulk tightened you line fittings at the factory and u also need crows foot sockets to do this project....... Fuel filter is always good maintance for your car even if it dont fix it. But that did the trick for mine after about 2k worth of brand new motor parts it was a 14$ filter :/
Old May 7, 2012 | 11:06 PM
viequense's Avatar
my bad...
ok it's been like that since i bought it
i havent try nothing yet waitting for some recomendations, i will try with the fuel filter and see if it gets better,
thanks for ur response guys!
Old May 21, 2012 | 09:44 PM
viequense's Avatar
Finally can check the car,
Results
Clogged fuel filter, bad ignition cable on piston number 3
I did myself a comple tune up
but now the car sometimes jumps when idlle
Could it be bad ignition?
Old May 22, 2012 | 04:03 PM
"Jumps" during idle?? You mean the idle surges up & down in RPM?
Set the base idle (see this thread).
https://www.hondaaccordforum.com/for...e-speed-38734/
If the idle had been improperly adjusted in an attempt to "fix" the fuel filter & tune-up stuff, you will now have to re-set it properly - now that you've fixed the other things.
If it still misfires, you're gonna want to adjust the base idle AGAIN after you fix that.
Old May 23, 2012 | 07:35 AM
viequense's Avatar
when i say jumps i meant misfires sometimes...
Is running normal but sometimes jumps.
somebody told me it could be a bad ignition
Old May 23, 2012 | 11:49 AM
Could be a bad ignitor (ignition control module) & some places like AutoZone can test em. You can measure resistance on your coil but I don't remember the proper resistance values.
With the engine completely cold, and total darkness (say 3:00am) open the hood & turn off all the lights. Start the engine & watch the distributor cap & plug wires. Any arcing (visible blue glow) means bad insulation.
Old May 24, 2012 | 07:27 AM
viequense's Avatar
ok thank u, i will try that
Old May 24, 2012 | 04:57 PM
Well, it's all 3 things, because they test different types of failure.
For example a coil can have incorrect resistance (failed) yet it's insulation can still be good. The arcing-in-the-dark test is for failed insulation, not as a substitute for the other testing.
frankenstein69
Dec 28, 2014 12:36 AM
Ineedhelp
Jan 22, 2012 07:29 PM
thebartender2010
Oct 24, 2011 11:51 PM
GOT BOOST
Nov 2, 2009 08:32 AM
msheehan
Mar 31, 2005 01:18 PM
