95 accord lx
You mean the exhaust manifold gasket? Or the actual head gasket?
Biggest pain is gonna be the bolt in the center of the crankshaft pulley. Don't start dismantling stuff until you get that loose. You might have to go to a shop & have them loosen it & re-install it a bit light so you can drive home & pull it off.
Look in the DIY section for a sticky post about on-line manuals. Get that & look at timing-belt & headgasket sections. Ever done a headgasket on any other car?
With engine running.... visually saw green coolant running down engine block. (not pouring out)
Right under the Exhaust Manifold is where we can see it leaking. Actually it drips down onto the single exhast pipe below O2 sensor and burns off.
Does that make sence???
No i have never done a head gasket. Step son has done a few on older trucks.
I did buy the chilton.
JHK
JHK
