95 Accord LX Largo
Old Sep 4, 2007 | 03:25 PM
smaglik's Avatar
Default RE: 95 Accord LX Largo
apparently there are numerous largos out there, cause the link i pulled was from somewhere around chicago.
Old Sep 6, 2007 | 12:28 PM
Samio866
God damn it now, the car won't start up... we changed the rotor and the cap... the and the coil... now we hafta change the ignition and it cost $$$!!!! Is it really the ignition? We did a spark plug test and its not giving out a spark... =[
Quite Earlier from that (yesterday) we were trying to figure out how to get the damn antenna to go down... and we was playing with the yellow wire and connecting it to whole buncha wires that go to the factory radio... i dont think that shorted out it because the engine still started while we were doing that... (I just thaught this was good to add here) and we were trying to adjust the passenger window motor to correctly go up and down without sticking and etc..
Old Sep 6, 2007 | 01:37 PM
00AccordLX5spd's Avatar
Registered User
Are you sure you hooked up all the spark plug wires in the right order on the distributor?
Old Sep 6, 2007 | 01:46 PM
falkore24's Avatar
Even the wrong order would still spark, just at the wrong time. Make sure that the coil is hooked up properly. Also, search the threads on here because I know that desserthonda has addresses ignition troubleshooting before.
Old Sep 6, 2007 | 02:06 PM
brayner's Avatar
ORIGINAL: Samio866
did the car run before you changed the rotor etc.?
the antenna goes down when you turn off the radio. Check the circuit at the motor.
Cleaning the window tracks may help your window issue.
Old Sep 6, 2007 | 02:55 PM
It is hard to screw up installation of the cap and rotor.
I would install the old coil to help verify that your new coil was working properly.
