95 Accord LX stalls and engine light
Old Jun 26, 2013 | 11:49 PM
Meklin89's Avatar
Default 95 Accord LX stalls and engine light
My 95 LX stalls and the engine light comes on when I reach 45-50 mph. When I shut it off it turns back on immediately with no problems. I just bought this car not too long ago so I don't know much about Honda's. I know how to find the CEL code just haven't done so yet. The light disappears after ****ting off and turning back on so I'm rather confused.
Any help would be appreciated.
Old Jun 27, 2013 | 01:20 AM
The code(s) are saved, so check the codes and post them on here. The code(s) will likely indicate a component that is activated at high rpm.
Old Jul 1, 2013 | 05:31 PM
Meklin89's Avatar
Okay so I finally pulled the codes. CEL Code is 15. What does this mean for me?
Also my SRS light shows code 51 before resetting it and now that I reset the SRS light it blinks continuously when pulling the codes. I'm rather confused about this...
Old Jul 1, 2013 | 07:06 PM
Engine Code 15 is ignition output signal and means the ECM is not seeing an ignition signal from the ignitor in the distributor. Replacing the ignitor is usual fix, but could be wiring or electrical problem. See following link for help.
Honda Acura Starting Problems Repair Guide, Main Relay Locations
SRS Code 51 is internal failure of SRS unit. No diagnostics offered. Suggest looking for a used unit on ebay or car-part.com.
Download the 94-97 Accord manual from Online Manuals post in DiY forum for procedure to install SRS unit. Don't try this w/o a procedure. Airbags could potentially go off.
Old Jul 3, 2013 | 12:50 AM
Meklin89's Avatar
So from what I have figured so far is I will have to replace the ICM/ICU whatever you call it. Any suggestions on a brand that is reliable and cheap?
Is there anyway to tell if my SRS unit is still under Warrenty? I read a few places that the units for this model year are under a lifetime Warrenty and possibly a recall as well. How and where do I find this out?
Thanks again
Old Jul 3, 2013 | 07:10 AM
Ignitor is < $35-$70, but I don't have any brands to suggest. Many folks simply replace the entire distributor because cost is not that much more, $50-$100. Check ebay for lowest cost options.
Old Jul 11, 2013 | 08:37 PM
Meklin89's Avatar
So I've bought a whole new distributor system. Where can I find info on how to replace it without going to a garage? My dad is good with mechanical stuff and has worked on his cars his whole life just never on a Honda.
Old Jul 12, 2013 | 05:39 AM
Check DIY forum and youtube for videos. It's straightforward job.
Only difficult part is engaging the distributor key into the camshaft end correctly. If you observe the direction of the rotor on the old distributor and insure the new distributor rotor points in same direction, you'll get it right.
Exchange old wires for new one at a time to insure correct order. Download a shop manual from DIY forum, Online Manuals post to get the correct plug order on the distributor.
Old Jul 12, 2013 | 10:26 AM
Meklin89's Avatar
Thanks!
Old Jul 13, 2013 | 07:47 PM
Meklin89's Avatar
Okay finally replaced distributor. Now I have CEL code 9 and CEL remains on while driving. Now what?
