95 Accord LX stalls and engine light
Old Jul 14, 2013 | 08:00 AM
Two possibilities are faulty distributor (bad parts do happen), or faulty ECM. This later posssibility seems unlikely since you did not have code 9 prior to replacing the distributor.
Suggest checking sensor resistance at the distributor connector. Resistance of the Orn and Wht wires (pins 4 & 8) should be 350-700 ohms for F22B2 engine which you have.
If resistance is good, then repeat check on same wires at ECM connector. If good again, the ECM is faulty.
If resistance is out of range at distributor, the distributor sensor is faulty and another distributor is required. If resistance is out of range at the ECM, a wiring fault between ECM and distributor connector is indicated.
Sorry for your problems. Is this a new or used distributor?
Old Jul 14, 2013 | 02:15 PM
Meklin89's Avatar
This is a new distributor. Not used or refurbished.
One thing I do remember is that when taking the connectors off the old distributor (which was a bitch because it was stuck from being there 20 years) I cracked the casing of the larger of the two connectors.
Also, how do I reset the CEL? Just remove the fuse for a few minutes?
Old Jul 14, 2013 | 07:03 PM
Pull BackUp fuse in underhood fuse box for 15-20 secs to reset ECU, or use obd2 scanner to reset.
mishakol129
Nov 20, 2011 06:10 AM
jason_home
Aug 29, 2011 11:02 AM
lionj
Jul 22, 2007 11:21 PM
verno
Jan 18, 2007 09:40 PM
