95 Accord LX, transmission replacement help
Old Mar 24, 2015 | 04:28 PM
Swimerbot's Avatar
Default 95 Accord LX, transmission replacement help
My transmission finally just went out so I'm swapping it with another one and following the shop manuals instructions, but I was wondering if all accessories need to come off or if it'll come out with some still on? And if there's any tips anyone can give me?
Old Mar 24, 2015 | 05:20 PM
Turtlehead's Avatar
If you are just doing a replacement then all parts can be reused. As far as tips that depends on if you have and auto or manual. I have to assume you have an auto since the manuals rarely fail unless not maintained properly. Either replacement is pretty simple especially if you lower the subframe bolts a bit.
Old Mar 26, 2015 | 02:41 PM
Swimerbot's Avatar
I do have an automatic transmission. I'm not familiar with the subframe bolts, could you elaborate?
Old Mar 27, 2015 | 04:20 PM
Turtlehead's Avatar
They should be the 17mm head bolts that hold the sub frame to the body of the car. Lower them a bit to get better access for dropping the transmission. But I caution you to not forget to re tighten them prior to driving.
mamtsberg
Mar 17, 2010 09:15 PM
s4m222
Dec 22, 2009 12:31 PM
mothman
Sep 16, 2008 03:34 PM
adamc44
Jan 27, 2007 12:22 AM
Handiman1
Sep 24, 2006 06:38 PM
