95 accord mt questions
Old Aug 9, 2011 | 07:53 PM
kd2aag's Avatar
Default 95 accord mt questions
what up guys got up this morning started the car and noticed a noise sounded like the starter was still engaged but slightly well i took the car to my uncle i started the car and then pushed the clutch pedeal to the floor noise went away , take my foot off the clutch pedeal with it in nuteral the noise came back my uncle said it sounds like a throw out bearing i called around to get some estaments on replacing the clutch,pressure plate , throw out bearing , and resuface the flywheel for 800 bucks , i notice a whine when driving long distances before the noise this morning does this sound lie a throw out bearing and not a tranny problem
Old Aug 9, 2011 | 08:50 PM
piggylover1985's Avatar
Sounds like a throwout bearing, but don't rule out the push pin of the slave cylinder where it contact with the throwout bearing shift fork is dry, it will make the same noise without the grease there.
Old Aug 10, 2011 | 02:18 PM
kd2aag's Avatar
well this morning i decided just to check the fuild in the tranny so i pop off the drian plug and had hardly anything come out so its not looking good the onlly thing that looed good was the magntic drian plug had no metal shaving on it. so i replaced the the fuild and the noises went away also shifts and goes into gear a lot better well i guess its good that i didnt spend that 800 on the clucth kit and throw out bearing i guess i need to be looking for a good used tranny hopefully this tranny will last until i find one and the whinning thaat i was hearing on the highwaay is now gone also maybe i didnt fry it to bad
Old Aug 10, 2011 | 02:59 PM
How much fluid did you have to add? Fluid doesn't magically disappear, so look for signs of transmission fluid leaking. It could be a slow leak. I would look around where the CV joints insert into the transmission.
The Honda manual transmissions are pretty solid, so maybe the low fluid didn't do permanent damage.
Old Aug 10, 2011 | 03:16 PM
kd2aag's Avatar
well it looks to have had a let a cv axle let lose at one time and it looks to have cracked the case and the previous owner used some jb weld to fix it i didnt notice this until i was under there today dosnt seem to be leaking bad so i imagine that its been leaking a while just never notice so for a tempery fix until i find a replacement trans o clean off the area and reaply so jb weld i have had the car for like 2 years and just notice it now so i think it might last a couple more months . oh i drianed it completely so it took 2 quarts to fill it maybe got a half a quart out of it
Old Aug 10, 2011 | 04:18 PM
If it drives ok and no more noises from the tranny then you're good, If you had the car for 2yrs without refilling the fluid then it wasn't leaking that bad then. Keep driving it and keep adding fluid as needed.
Old Aug 10, 2011 | 05:19 PM
kd2aag's Avatar
i just got done cleaning off the jb weld that was on there i couldnt see any cracks at all not saying there isnt any but i cleaned off the area rought the area and reapplied some jb weld over the area . if it continues to leak it has to be coming from the seal were the cv axle goes into tranny is this correct there is a seal were the shaft goes into tranny ????
Old Aug 10, 2011 | 06:16 PM
Most likely, but don't forget to check for the shifter arm seals on top by the shifter tower. I just got mine replace, it was leaking decent amount of fluid, i thought it was the axle seals so i replace them and still leak wth ? I looked up higher and found the shifter shaft seals are leaking.
Old Aug 10, 2011 | 06:40 PM
kd2aag's Avatar
how hard was it to replacce them the shifter seals ??? and was it a fair amount of fluid coming out ?? just courious
Old Aug 10, 2011 | 06:58 PM
decent amount of fluid, get right axle all soaked. All three seals cost under $20 from Honda, it fairly simple to replace them seals with the shifter cable disconnected and remove the shifter tower, you will also need a roll pin punch to remove the shifter arm out. Your tranny should be somewhat similar to mine. Check on the shifter tower for leaks before you changing the seals, here is the picture, looking at number 10,15, and 16 Part Detail
accordrider4life
Feb 5, 2006 12:15 AM
DVan8504
Jan 7, 2006 06:46 PM
rbeyer
Oct 11, 2005 02:53 PM
doriftoking
Oct 6, 2005 11:40 PM
sviana
Dec 7, 2004 03:09 PM
