95 Accord speedo
Old Apr 22, 2008 | 08:30 PM
Cee
Default 95 Accord speedo
Hi I'm new to this forum but I have a ? My speedo does'nt work they said it was a sensor so I changed the sensor. Is it possible that I need a new cluster because when you turn the car on it jumps to 20mph
Old Apr 22, 2008 | 08:49 PM
Default RE: 95 Accord speedo
If the cruise control still works while the speedometer is stuck at 20mph, then the speedometer is bad.
I had mine stuck at 20mph as well. I sent off my speedometer to a repair shop that I found online. I didn't want the mileage on the odometer to be different. It has worked flawlessly since it was repaired.
Old Apr 22, 2008 | 09:05 PM
Cee
Thank's for your help how much was it to fix your speedo & what site is this?
Old Apr 22, 2008 | 11:12 PM
If I remember right, it was ~$110. Honda wanted about the same price for a new one and they wouldn't roll the odometer to match my mileage. That is why I just had it fixed.
It was called Powls speedometer repair. I just googled speedometer repair shop, then called and asked if they knew how to fix the problem with my speedometer. They said that they could fix that. I'm not sure what they did.
chevync208
Jul 16, 2009 11:16 AM
madsteez
Oct 28, 2008 09:27 PM
spidremedia
Sep 12, 2008 11:53 PM
GoJackets
Jul 26, 2008 04:59 PM
cook393
Mar 1, 2008 02:10 PM
