95 accord stalling like i turned the key off
I have a 95 accord with 115k miles. It stalls with no signs that its gonna stall. It just stalls like i turned the key off but lights n everything stay on. Hard to start back up but will start with a few turns of the key. Already changed the ignition switch. Main relay. Map sensor and idle air control valve. Does anyone have any tips on what to do next? It stalls at idle and while driving but not all the time if the car is warmed up it doesnt seem to do it
It will start idle n drive fine. But stalls intermittently without any signs. Ive driven 2 hours with no problems n other times it will stall. If i let it idle like 15 mins before driving it doesn't seem to stall. But other times it will stall at idle. Lol
Check the battery terminals and connectors. My 95 Blazer used to just cut off like that with no warning. I eventually noticed the loose connection to the battery and replacing the terminal fixed it right up. Hope this helps.
Please stop throwing parts at the car and do some diagnostic work.
How many miles do you have on the maintenance items like the spark plugs?
Check for engine and transmission codes. See link in this thread:
https://www.hondaaccordforum.com/for...threads-40780/
You need to determine whether fuel or spark loss is causing engine stall.
When no start occurs, listen carefully when you turn keyswitch to On. Lights should come on and fuel pump in fuel tank should buzz for 3 secs and go off (same time Check Engine Light goes off).
If you're not getting fuel pump action when no-start occurs, then either power to the fuel pump is missing (faulty main fuel relay likely), or fuel pump is sticking (faulty fuel pump brushes/motor).
If you're getting fuel pump action every time key is turned to On when no-start condition is present, lack of spark is likely cause; ignitor, coil, rotor, cap fault.
mchl_hoy
Sep 19, 2009 10:21 AM
blan
Mar 31, 2008 11:45 PM
