'95 Accord V6: Replacing Ignition Coil
Old Jul 22, 2008 | 01:22 AM
yeaaa
Default '95 Accord V6: Replacing Ignition Coil
My tachometer isnt working and the check engine light is on. Did some searching and it seem to be the ignition coil that is causing CEL to go on. Anyone with service manual can help me with replacing it?
Old Jul 22, 2008 | 07:18 AM
Default RE: '95 Accord V6: Replacing Ignition Coil
95 V6 is OBD-2 - one year early.
Go to AutoZone to read the error code. Give us the actual error codenumber, not the guys explanation.
But you are correct. Unlike most other Accords, YOUR tachometer signal comes from the coil.
Old Jul 22, 2008 | 07:27 AM
Your coil is external (#5). Plug & Play.
Old Jul 22, 2008 | 09:30 AM
00AccordLX5spd's Avatar
Registered User
First of all, your car may still be under warranty. There is an extended warranty for 94-97 Accords. As long as you have less than 150k miles and the car is 14years old or newer, the coil is covered under the warranty. Just google “Honda Service Bulletin 98-081†– a dealer will replace for free if still under warranty.
Old Jul 22, 2008 | 11:06 AM
yeaaa
Default RE: '
I dont know about you guys but AutoZone in my city, Sacramento, are not allowed to do free scanning anymore. Something about deallership bitching to the congressman. Also, my car is way over 200k miles so its not still under warannty.
Old Jul 22, 2008 | 12:17 PM
yeaaa
Default RE: '
How do I correctly remove the distributor? So I can get to the two back bolts on the ignition coil.
Edit: Nevermind, I figured out how to do it. But, is it important/neccesary to replace the o-rings or can I just reuse the old o-rings that are already there?
Old Jul 22, 2008 | 06:41 PM
yeaaa
Default RE: '
Replaced the ignition coil. Problem is now solved. Tach is working and CEL has disappeared.
anupm12
Apr 27, 2015 04:23 AM
phantomgrey92
Oct 9, 2013 04:45 PM
Lorenzo816
Aug 21, 2012 02:01 AM
chrissbee77
Jul 28, 2008 06:13 PM
