97 Accord ignition coil
Old Jul 27, 2008 | 08:11 PM
chrissbee77
Default 97 Accord ignition coil
I have a 97 accord v6 non vtec and the tachometer bounces around and it through a check engine code. It was thevehicle speed sensor but i was told by a lot of people that it wasn't that it was a bad ignition coil. How the heck do i change the coil i cant seem to get to all of the bolts and is there a way to test the coil. This is my first post and look forward to posting again thanks for the info and help
Old Jul 28, 2008 | 08:17 AM
Default RE: 97 Accord ignition coil
VSS should cause flaky speedo, not tach. Reset ECU & see if VSS code comes back.
I dont have a V6 so cant help with the brackets.
https://www.hondaaccordforum.com/Sti..._128656/tm.htm
Old Jul 28, 2008 | 06:13 PM
19Accord97
00Accordlx (on the top 10 posters) im pretty sure had the same problem in a 96. Id send him a pm/email. i think it was the vss
anupm12
Apr 27, 2015 04:23 AM
phantomgrey92
Oct 9, 2013 04:45 PM
Lorenzo816
Aug 21, 2012 02:01 AM
yeaaa
Jul 22, 2008 06:41 PM
