95 accord wont start
First, I have read many posts on this subject but haven't been able to figure it out. I have limited ability and tools....so.... my 95 Accord, manual transmission was running great and then just wouldn't start. No clicking at all. Lights and radio work...lights don't dim when turning the key. Rolled it down a small hill and 'clutch' started it to get it home, so it stills runs, just a big nothing when you turn the key. I have not found any kind of alarm system, so I don't think that's it. I removed the steering cowling and the 'little white circular' thing opposite side from the key appears to be new...no corrosion. Ideas?
I think I do have a volt meter...and...I seem to recall seeing something similar to the picture you sent...although it would have been a while before the problem started
Find the volt meter.
The small wire to the starter, pull it off - it is a simple "push on spade" connector under the boot.
As someone tries to start the car - measure the voltage on that wire - are you getting voltage to that "end/wire"?
Got a brand or something? I might be able to find a user manual thru google or something to help out.
You can try a few things. It should have a black and red "probe"......try to find a "voltage" setting - touch the black probe to the battery ground and the red to the positive on the battery......do you get a reading of ~12 somthing on the the meter?
