96 accord electric promblem
Old Dec 12, 2012 | 01:30 PM
adielramirez's Avatar
Exclamation 96 accord electric promblem
hello guys i am new to the form!
i have a 96 accord lx was auto i made manual 2 years ago but recently i had a promblem with the electric i get electicity on the fire wall n also at the ac presure hoses n it melt the gas pedal cable???
what can b causing this problem??????
Old Dec 12, 2012 | 03:04 PM
Did you replace any fuses with a higher amperage fuse than specified? If you did use a higher amperage fuse, more electricity is allowed in the circuit and higher chances of damage can occur.
Otherwise, there is a short in a wire or electrical connector. A short is an accidental connection of a wire to ground or to another wire.
Old Dec 14, 2012 | 09:27 AM
Roader's Avatar
Sounds like a bad engine ground. See this thread:
1996 Accord Main Relay Ground
Old Dec 15, 2012 | 09:41 AM
idk i am gonna make a video to show u guys the problem
with the the problem i check all the fuses there all are place as they suppoust to be!!! ohhhh also for got to let u guys know that i have 8.5 ngk spark wires also i have a after market batery wiring ??? with hid headlight i am taking pic to post for u all ???
volvoman
Apr 9, 2014 01:59 PM
whitetailkiller-2008
Jan 18, 2011 12:09 PM
LambertJohn
Sep 17, 2010 01:47 PM
flbob
Sep 15, 2010 03:31 PM
03 Coupe
Feb 22, 2007 06:32 PM
