96 Accord F22B1 OBD1 to OBD2 Swap
Old Nov 20, 2015 | 10:31 PM
kdagenais's Avatar
Default 96 Accord F22B1 OBD1 to OBD2 Swap
Hello,
Been looking for details on what is involved to make a F22b1 convert from OBD1 to OBD2. Lost engine in 96 OBD2 and found a OBD1 engine and want to make it drop in car as it was. It appears I need to change the oil pump housing and not sure what else. Any help will be greatly appreciated.
Old Nov 21, 2015 | 08:09 AM
There are a few ways to go about this.
Yes the distributor is the biggest issue/change that you will need to decide which way to go.
Decision point - do you want to use the dist from the 95 or the 96?
Old Nov 21, 2015 | 08:43 AM
kdagenais's Avatar
Have to use 96 dizzy for the other didn't come with it.
Old Nov 21, 2015 | 08:56 AM
Then yes, you will have to swap the oil ump housing and sensor from the 96 to the 95. Then since you are "there" you might as well do the timing belt job - you will now have a "base line" as to when it was last done.
Old Nov 21, 2015 | 10:29 AM
kdagenais's Avatar
Was hearing something about one of the timing bolt sprockets to. Is this true.
Old Nov 22, 2015 | 05:03 AM
The crank pulley for the belt is different. Basically the whole housing and anything "forward" of it will have to be moved.
At some point you might want to think about the cost of a new/used dist for the 95 and just run some new wires.
Attached Thumbnails 96 Accord F22B1 OBD1 to OBD2 Swap-5th-gen-oil-pump-housing-odbii.jpg
Old Nov 22, 2015 | 07:13 AM
kdagenais's Avatar
Got it all apart wasn't that bad to take apart. Wanted it all resealed anyway. Thanks for the info hope to have together in the next couple days.
elmerochingon
Oct 25, 2012 10:21 PM
Jap.Doe
Jan 23, 2012 11:59 PM
Bacondoggy
Oct 5, 2009 10:27 PM
spool666
Feb 2, 2008 08:30 AM
Blacklisthunter
Nov 14, 2005 05:57 PM
