96 Accord Fans Won't Work
Old May 19, 2013 | 06:50 PM
vertigoomg's Avatar
Default 96 Accord Fans Won't Work
So I've already replaced both the fan relay thingy and the fan fuse, and neither did anything. Turning on the AC does nothing. I /think/ a corroded wire going into the fuse block might be the culprit, but I honestly do not know. I have a couple questions.
A. How do I test the fans to see if they work, at the very least the radiator fan?
B. I've tried PB Blasting the screws connecting the wires to the block and still cannot undo them. Any other ideas?
Old May 19, 2013 | 07:32 PM
I will assume this is a four cylinder? If it is a V6, then ignore the information. Put your vehicles information in your signature, so we don't have to ask.
Before we start testing, both fans turn on to cool the radiator when the engine is running even though they are called radiator or a/c condenser fans.
1. There is a green electrical connector on the thermostat housing. It has two wires on the electrical connector. With the car turned off, unplug that connector, take a piece of wire and jump the connector with a piece of wire. Turn the key to the II position. Both fans should turn on.
2. What wires are you talking about?
Old May 25, 2013 | 02:17 PM
vertigoomg's Avatar
I'll try bypassing the thermostat switch to see if that works. As for the wires? They go to the relay box under the hood, passenger side towards the firewall. I'll take a picture soon.
Jenny Jordan
Dec 22, 2023 11:04 AM
choclatesushi
Aug 20, 2012 09:24 PM
beto
Aug 8, 2011 12:30 PM
ac398
Feb 15, 2010 11:48 AM
myrsaccord
May 2, 2008 01:04 PM
