Fans do not work.
Old Aug 8, 2011 | 12:18 PM
beto's Avatar
Default Fans do not work.
Radiator and condenser fans of my 1993 Honda accord work only when I turn the A/C on. I would like to know what the problem is. I appreciate any help. Thanks.
Old Aug 8, 2011 | 12:30 PM
There is a two-wire thermoswitch A on the thermostat housing below and behind the distributor. You will need to pull the intake duct for access.
Remove the connector from thermoswitch A, short the two connectors w/ a jumper wire, and turn keyswtich to ON. Both fans should come on and run. If fans run, a failed thermoswitch A is confirmed. Replace thermoswitch A w/ new OEM unit.
These fans will only run when coolant temps is > 194F. I've found that many times the engine runs sligtly cooler than this and fans never come on. There is enough cooling air from forward speed to maintain coolant temp.
vertigoomg
May 25, 2013 02:17 PM
choclatesushi
Aug 20, 2012 09:24 PM
ac398
Feb 15, 2010 11:48 AM
myrsaccord
May 2, 2008 01:04 PM
depezhe
Nov 25, 2006 09:20 PM
