96 Accord stalling
Old Oct 17, 2013 | 09:00 AM
xyeah's Avatar
Default 96 Accord stalling
Hi everyone. Thanks in advance for any advice you have for me.
I just bought a 1996 Accord, drove it home just fine. That same night, drove it around just to drive it and nothing wrong. Needs new brakes but that's about it. The next morning it was a little chilly, turned the heat on, it started sputtering. Didn't think much of it since I had just started the car and it had been sitting for awhile anyways before I got the car. Started driving, got to my second stop sign and the car stalls. Turn it back on, continue driving. Each time I came to a stop the car would sputter more. It died 2 more times in about a 10min time on my way to work. Forgot something at home when I got to work and after the car died on me again trying to get into the parking deck I just figured I would drive it home and get my other car. Again, still sputtering when I stop. Finally I turned off the heat and then it seemed fine. I turned it off when I got about half way home and everything was still normal when I got home.
Should also add that each time it stalls, the headlights stay on and the radio too.
Any guesses on what is causing this?
Thank you!
Old Oct 17, 2013 | 04:15 PM
94ex915's Avatar
Almost A Senior Member
Thank you!
I know mine acts this way when the A/C button is on. Not to sure of the problem.
Old Oct 18, 2013 | 07:31 AM
xyeah's Avatar
I haven't tried the air yet. I guess I should see if it does the same thing if the air is on as well. I drove it around yesterday without the heat and again, nothing wrong. But I did notice the temperature gauge seeming to take a while to move off of cold. I haven't seen it half way any of the times I drove the car. I'll have to look into that more and maybe leave the car on longer and take a look at it.
Old Oct 18, 2013 | 02:31 PM
jroxz44's Avatar
My temp gauge only moves a quarter of the way up..... yours is fine. But I would check your IACValve and try cleaning it. There are sticky threads all over about it. Then also after its clean set your base idle properly. (Also stickyed ) see if that helps then let.me know . Good luck
Ayam A. Mowran
Mar 25, 2007 05:27 AM
needhelp
Sep 27, 2006 02:09 PM
eckhart
Apr 7, 2006 12:32 PM
thigley
Jan 5, 2006 11:46 PM
mercski
Nov 26, 2004 07:39 PM
