96 accord wont start
Old Jul 22, 2012 | 10:26 AM
kgorman1993's Avatar
Default 96 accord wont start
I have a 96 honda accord that sometimes wont start. In order to get it to start you have to cycle the key a few time and wiggle the shifter repeatedly. The car when have having this issue will just click the starter. other than that the car runs fine when started. Any suggestions to what it could be?
Old Jul 22, 2012 | 11:09 AM
I've moved this to General Tech - fits a bit better here.
Do you have a volt meter to do some testing?
There are a few things that come to mind and instead of wasting money by replacing a bunch of stuff it would be better to narrow it down.
Starter going bad, weak battery, gear position switch not working, shift cable adjustment, bad connections on the battery....I could keep going
Old Jul 23, 2012 | 09:59 AM
ok. i will test those out it seems to have a better chance at starting if the engines cold if that changes anything?
Old Jul 23, 2012 | 08:33 PM
If you are going to test things and have a volt meter.....start with reading the voltage on the battery at "rest"......I know this is only one simple test.
Next would be to read the voltage at the starter - small wire first - when trying to start the car.
Tony1M
Nov 6, 2023 08:29 PM
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
MrGmo
Sep 28, 2007 01:40 AM
booter
May 11, 2005 02:26 AM
