96 Coupe Fog Lights Help!
Old Jan 27, 2014 | 05:19 PM
Chiieff702's Avatar
Default 96 Coupe Fog Lights Help!
I've been trying to wire my fogs through the firewall of my accord but I can't seem to find a way to put the wiring through. I've heard people drilling holes & some wired it through the passenger door but I'm not trying to do that if there's another possible way. Please help! Thank you in advance!
Old Jan 27, 2014 | 05:35 PM
Isn't it already in the wiring harness?
Even if you're not using the factory foglight kit, try to download the install instructions. Pretty sure you can pick up the wires that are already in the harness.
Old Jan 29, 2014 | 01:09 PM
Chiieff702's Avatar
Ya but I can't seem to find a way to get the wiring to my fuse box. Cant seem to find a spot in the firewall.
Old Feb 1, 2014 | 08:45 AM
I think, too cold to go outside right now, there is a gromet kind of under the brake booster.
Or from the drivers floor look to the far left of the firewall and you should see a "mess" of wires going thru the firewall.
Old Feb 1, 2014 | 08:02 PM
johnrmcnary's Avatar
what are you doing to wire them up? Did they come with a Relay kit? If so, you only need to run 1 wire in the cabin to a switch. You should be able to do that alongside the other wires
GBL1
Oct 30, 2009 06:54 AM
accordking
Jun 6, 2009 12:08 AM
accordking
May 13, 2009 07:38 PM
jimmyznutz
Mar 3, 2007 02:21 AM
crazielude
Dec 20, 2006 01:53 PM
