01' coupe fog lights
Old Jan 31, 2007 | 08:56 AM
jimmyznutz
Default 01' coupe fog lights
Does anyone know where to find some fogs for my 01' coupe? I've seen plenty of the setups for the 4door on Ebay, but not 1 coupe set. Are they the same kit or is there a kit made just for the coupe?
Old Feb 5, 2007 | 10:23 AM
jimmyznutz
Default RE: 01' coupe fog lights
Well then. Another question noone seems to know the answer to.[sm=dontgetit.gif]
Old Feb 27, 2007 | 08:23 AM
Peter Griffin
Boy, been wondering the same thing for my 01 V6 coupe. It's like there's foglight kits for exery year but 2001!! I can bolt-on anything, but that nice clean OEM insert would be a cleaner install.
Old Mar 1, 2007 | 02:48 PM
midnightfreak
One of my fog lights is cracked (01 coupe as well) and this is the only place i found that has them. Alhtough they are pretty expensive.
http://www.handa-accessories.com/accext01.html
I want to know if any other foglights will bolt into the factory locations, because if i have to spend that much money i would rather get a high performance set for the same price, expecially since i already have the factory inserts.
Old Mar 1, 2007 | 04:41 PM
Peter Griffin
Yea, I checked out H & A, but found the kit cheaper on ebay. Do a search for "01 accord fog light" & you'll find it for $220.
No other foglight will fit into the OEM setup, but some small projector-style would probably do the job once you have the right insert piece. Check out this one: http://cgi.ebay.com/ebaymotors/98-99...spagenameZWDVW
Old Mar 1, 2007 | 04:44 PM
Peter Griffin
here's the link to the fog light kit:
http://cgi.ebay.com/ebaymotors/ws/eB...0132647&rd=1,1
I called them prior to them listing it for $219.95. They said it was $243 over the phone & then I saw that they listed the kit on eBay about 2 hours later. So, $219.95 is a good deal, but too expensive for just fog lights. They don't add enough looks or light for that price. I'd rather upgrade my headlights to HID.
Old Mar 1, 2007 | 05:44 PM
midnightfreak
I agree that they are just too expensive. They are not as bright as high performance ones for the same price, and do not add anything other than looks really. If i cannot find a set that will bolt into the factory location then i will most likely just leave them be.
Old Mar 2, 2007 | 05:26 AM
Peter Griffin
so, what do you think about those inserts that i linked to above? some small projectors would probably work with those inserts. no matter what, though, the front bumper needs to come off. it is really easy. i have the haynes manual & it shows 15 or so screws that come out & then viola! anyway, not worth it.
Old Mar 3, 2007 | 02:21 AM
midnightfreak
Yeah i do not think it is worth it. The inserts look ok, but if they only stick on with tape i am not sure how good it would hold. Plus on top of that you have to get the actual fog lights.
hothands
May 7, 2010 07:33 AM
GBL1
Oct 30, 2009 06:54 AM
accordking
Jun 6, 2009 12:08 AM
accordking
May 13, 2009 07:38 PM
crazielude
Dec 20, 2006 01:53 PM
