96 EX V6 Intermittent AC cooling
Old Jun 3, 2008 | 12:46 PM
Default RE: 96 EX V6 Intermittent AC cooling
Seems like the possibilities would go like this...
1- breaks in the wire making up the coil would make it go to open-circuit.
2- shorting between adjacent turns in the coil would make resistance go down. Pulling in the AC clutch, this would generate less force than it's supposed to.
With 2 different meters BOTH reading low, maybe that's exactly what happened??
Old Jun 3, 2008 | 05:30 PM
Most likley option 2, internal shorts, however resistance readings can be misleading. I agree it would be a bad day to reinstall w/ reduced gap and find the same problem. If the compressor is very difficult to access, I would replace the clutch coil to be on the safe side. However if relatively easy to access, I would try just readjusting the gap.
Old Jun 9, 2008 | 09:13 AM
kerhaf
To close this thread out, I took the car to a trusted mechanic & for 1 1/2 hr labor they adjusted the air gap back into spec & the AC is cooling great again. Thanks for all the assistance here. Hope this thread helps someone else. Kent
mattcadieux1
May 8, 2013 08:45 PM
SlyBlackDragon
Jan 6, 2012 10:13 PM
echolsautosales
Mar 16, 2006 11:07 AM
emaxxman
Feb 19, 2006 03:07 AM
cyurgeles
Jan 21, 2006 10:36 AM
