96 Honda Accord F-22 B-1 VTech starts but won't stay running
Old Feb 22, 2013 | 02:38 PM
Lilmarkwoods's Avatar
Angry 96 Honda Accord F-22 B-1 VTech starts but won't stay running
I recently did a motor swap out of the 94 Honda Accord DX into a 96 Honda accord DX switched all the sensors did everything correctly timings correct. Car try's to start but won't stay running. Got the code reader on it changed crankshaft sensor change temperature sensors the car will start if I suck gas down the intake PCV valve. But then runs like ****. As soon as I kill it I have to do the same thing to get it started Again wtf...
Old Feb 22, 2013 | 07:25 PM
Throwing any codes?
Old Feb 23, 2013 | 09:09 AM
Problem description suggests no fuel delivery.
Can you hear fuel pump come on when keyswitch is turned to On and run for 2-3 secs? If not, then check main fuel relay, ignition switch, and fuel pump.
Old Feb 23, 2013 | 11:17 AM
Check the main ground on the end of the TB to be sure it is clean and tight (G101).
Attached Thumbnails 96 Honda Accord F-22 B-1 VTech starts but won't  stay running-5th-gen-g101-location.jpg
lidibolton
Oct 31, 2022 04:08 PM
CathyW
Apr 11, 2015 06:42 AM
Ookie833
Oct 3, 2013 06:30 PM
Norac1983
Jun 28, 2011 08:17 PM
sparkyg
Jul 12, 2006 09:41 PM
