96 LX D4 light
Old Jul 26, 2009 | 12:18 AM
accordn00b's Avatar
Default 96 LX D4 light
D4 light randomly went out. all other "d" (d3, 2, and 1 still work along with N and R and P). suggestions on the problem? could the light just be burnt out?
Old Jul 26, 2009 | 02:38 AM
poorboy_616's Avatar
Chances are it's just burnt out. As long as it's shifting fine, don't worry about it.
Old Jul 26, 2009 | 09:13 AM
The tiny bulbs can be replaced and are available. However, you have to pull the instrument panel (not difficult) to access and repair. Some simply move the D1 bulb (almost never used) to the D4 position. D4 light has added function of indicating a transmission fault code is present, so its good to have working. Although w/ OBD2, you don't really need this function.
Old Jul 26, 2009 | 11:38 AM
accordn00b's Avatar
do i need to reset my ECU at all while doing this? (do i just pull the fuse?) i have 210,xxx and it's shifting fine on the original transmission. would the CEL come on if it were a transmission issue?
Old Jul 26, 2009 | 12:18 PM
I reread your original post and was slightly confused. If D4 light is going on/off, then replacing bulb or moving D1 bulb is unlikely to fix. If it went off and stayed off, D4 is likely bad and can be fixed w/ replacement.
No need to pull a fuse. Most of dash is cold when keyswitch is OFF in any case.
Yes, w/ OBD2 the trans codes all set Pnnn codes. P0700 is apparently set when any trans code is present.
Old Jul 26, 2009 | 12:31 PM
accordn00b's Avatar
it's out completely. i'll replace it here within a week or two hopefully.
thanks.
62maxx
Oct 26, 2006 01:04 PM
ukcoupe
Oct 18, 2006 09:31 AM
bigdude
Oct 1, 2006 07:03 AM
hotrod01
Nov 11, 2005 01:28 AM
