97 Accord A/c not working
Old Jul 15, 2011 | 08:21 AM
ayang's Avatar
There are wires that run to AC pressure switch and radiator (pax side) fan. These are likely damaged and will require some wire splicing.
If you intend to DIY, download the 94-97 Accord manual from Online Manuals links in DIY forum. This has wire colors, pressure switch location diagram, etc.
How do i know that the cause is the A/C pressure switch? or A/C button on the dash? Also if it is, how do i get to the switch from the dash and what should i look for to see if switch is the broken?
Old Jul 15, 2011 | 02:42 PM
To figure out what is wrong, you will need a volt meter and will have to do some testing. You will have to know how to test for voltage on a wire and how to check that a wire is grounded.
Gangsta101
Feb 10, 2013 01:50 AM
LaGirl
Apr 24, 2012 05:29 PM
MoDawG
Dec 10, 2009 07:00 AM
sthavorn
Apr 7, 2007 10:12 PM
arunsam3000
Mar 6, 2007 01:40 PM
