97 accord died. Will turn over, but won't start.
Old Nov 8, 2011 | 05:12 PM
Quintin's Avatar
Default 97 accord died. Will turn over, but won't start.
I'm sure this is the millionth "car died, won't start" post, but I need some help.
The past 5 times I've driven my car it had trouble starting up, it would turn over kind of slow and then finally fire up.
The last time I drove it, I put $25 in the tank, drove about 5 miles and then it just cut out. It sputtered, then stalled.
All the dash lights/headlights/radio stayed on, but the engine just died.
It would turn over, but it wouldn't start up.
I got it towed home, waited until the next day, hooked it up to some jumper cables ( I had drained the battery out trying to start it) And the same thing is going on: It will turn over, but it won't start.
I thought maybe the main fuel relay, but I can hear the fuel pump prime when I turn it to accessory. I can also here the "3 clicks" in each key position.
I tried diagnosing it using this: CEL Check Engine Light
but I am only getting 1 quick blink, which would be the O2 sensor.
Should I just try replacing the main fuel relay anyways?
Could it be the distributor?
I don't know a whole lot about cars, so anything will help.
Thanks
Old Nov 8, 2011 | 05:27 PM
Do you have a test light or volt meter? If so, check for 12v on the BLK/YEL wire at the dist with key on/position two.
If you have a timing light, check for spark while trying to crank the car.
Old Nov 9, 2011 | 09:30 PM
Quintin's Avatar
Default re:
I don't know what the "12v on the BLK/YEL wire at the dist" is.
I checked the fuses, I can hear the fuel pump prime, I put new cap, rotor, plugs, and wires on it, it seems to be getting spark, but it just won't start
Old Nov 10, 2011 | 05:33 PM
Need to verify spark or lack of. Checking for 12v on the blk/yel would confirm voltage TO the dist. In the link below there are a few methods of checking for spark.
Honda Acura ignition (no spark) troubleshooting tutorial - How to
marin_accord
Oct 12, 2018 02:53 PM
Steadyone
Nov 13, 2014 08:28 PM
lecola
Oct 12, 2012 03:28 PM
