97 accord heater core replace now wire issue!
Originally Posted by ihouston45
both idle air control and intake air temp sensor. the idle air control i believe may actually just be the iacv itself because when testing the wires i get a proper 5vref and ground. the intake air temp on the other hand i replaced the sensor and that didnt help, when testing the wires neither wire is getting proper ground and boths wires are actually getting positive voltage one wire getting around 10v and the other around 12v. my understanding is one wire should be a 5 volt reference and the other grounded from ecu.
yeah i literally dont understand how its even possible unless the wires shorted together but theres no continuity between the two blowing the thought out the door. ill check that ground you mentioned then im also gonna get down to the ecu and test the pins for 5 v ref and ground for the intake air temp sensor
intake air temp wire colors yel/blk, blk/blu. iacv wire colors grn/blu, red/yel
so heres what ive come up with when testing the 5 volt reference for the intake air temp sensor at the ecu it reads normal around 4.8 volt but yet again at the plug for the sensor it reads like 10v so weirdly enough i guess my conclusion is somewhere along the lines its arcing with another power wire giving the wires more voltage then what should be going to the connector so my solution unless somebody else has a better one is the cut isolate and remove existing wires for the intake air temp sensor and run new ones getting the proper 5 volt ref and ground.
Haha. I'm glad it was a very simple fix and you didn't splice into wires unnecessarily.
For others reading this post in the future: The 94-97 4-cylidner accord, the map/tps, IACV/IAT, or the connector for the resistor block/some other connector nearby are identical connectors that can accidentally get switched.
