97 Accord stalling
Old Jan 25, 2010 | 09:59 PM
g_mac2112's Avatar
Default 97 Accord stalling
Hello all,
This is my first post I have been lurking for a while. Lots of great info around here so thanks in advance for your help.
My 97 Accord dies out once in a while and starts right back up. It will die anytime at a light or on the freeway, doesnt matter. The tach will start moving around and then it turns off. It seems to only happen when its warm/hot outside. Now that the weather has cooled off it hasnt happened in a while. Any help is greatly appreaciated.
Old Jan 25, 2010 | 10:50 PM
Does your check engine light come on? You should stop by autozone and have them scan for codes just to ensure that no codes are stored on the ECU. Post any codes on here. The start with P and have 4 numbers.
The connector is behind your ash tray.
Can you get the car to stall by shaking the key when you are driving?
Old Jan 25, 2010 | 10:51 PM
Also, are you maintenance items up to date, like spark plugs, distributor cap, rotor, etc...
Old Jan 26, 2010 | 06:59 PM
g_mac2112's Avatar
The check engine light does not come on and I tryed shaking the key around but nothing happened. The car is not up to date on maintenance items but it runs like a champ.
Old Jan 26, 2010 | 07:59 PM
Before diagnosing any stalling problem, you need to get those maintenance items up to date. Those parts do wear out over time and can cause stalling problems.
Stop by a parts store and have them read the code(s) while you are there. Also pick up spark plugs (cost ~$6, get NGK ZFR5F-11). Those are the copper V-Power ones. A distributor cap and rotor are probably around $25.
Old Apr 21, 2010 | 06:47 PM
g_mac2112's Avatar
OK my maintenance items are done. Still having the same problem. The check engine light is now on but it never came on before so it may not be related. I stoped by autozone they cannot check for codes anymore here in CA.
I did notice the check engine light flickering right before the car dies then the light goes off when it dies.
Old Apr 21, 2010 | 09:44 PM
bob91's Avatar
Camshaft sensor or crankshaft sensor
Old Apr 21, 2010 | 09:53 PM
Wow, what do people do in California? Check other chain-stores like PepBoys or PartsAmerica??
I'd want to read the code not just guess.
Old Apr 21, 2010 | 11:26 PM
Your 97 accord will have just the blue 2-pin connector under the glove box, and not the 3-pin connector next to it in the link below for instructions. Just replace [dot] with a .
All you have to do is short it with a thin paperclip or a piece of wire and follow the instructions to get the code(s) the OBD1 way.
www[dot]dhost.info/accordinfo/howto/cel.html
Old Apr 21, 2010 | 11:46 PM
I cant hardly believe that AutoZone cant check codes in your state.
Go on there website and ask that question in there..
Let me know...
