97 accord v6 auto
Old Apr 15, 2014 | 07:01 PM
TexomaAccord's Avatar
Default 97 accord v6 auto
There is this canister under the hood that has a hose on the bottom of it. The hose follows the red line and connects to "something". Then another part of that hose is just dangling under the car... Where does that go?
Attached Thumbnails 97 accord v6 auto-wp_002161.jpg   97 accord v6 auto-wp_002159.jpg
Old Apr 15, 2014 | 07:35 PM
It's a drain tube, that's how it suppose to be. It's the drain tube (part #7) in the parts diagram.
I also included some other diagrams, even though they don't clearly show a drain tube connected to the canister like the parts diagram.
Attached Thumbnails 97 accord v6 auto-canister.jpg   97 accord v6 auto-accord-v6-vacuum-hose-routing.jpg   97 accord v6 auto-accord-v6-emission-schematic.jpg
Old Apr 15, 2014 | 09:26 PM
Ah okay. Thank you. Now I have to figure out why my check engine light just came on after getting my stock exhaust wielded up
Old Apr 16, 2014 | 09:00 AM
Get the error code. Many places like AutoZone read em for free.
Post the actual code number, not just the guy's explanation (which can be quite creative).
Old Apr 17, 2014 | 08:26 PM
Replaced cap today. Had the negative cable disconnected. Check engine light went away, but if it returns, I'll post it.
Old Apr 21, 2014 | 09:21 AM
Code 8
8 long check engine flashes, no short
Or Code 80
Old Apr 21, 2014 | 09:42 AM
Sounds like you have code 80
Code 80 Exhaust recirculation system
Could you explain in more detail what you had done to the exhaust?
Old Apr 21, 2014 | 09:55 AM
The resonator was bad, so they cut it off and put in a straight pipe
Old Apr 21, 2014 | 09:58 AM
Well cleaning the EGR ports is where I would start with this one. Most of the times the problem is just clogged ports.
Old Apr 21, 2014 | 10:01 AM
267k miles, probably does need cleaning
Never done that before, will be a new learning experience for sure.
