97 Honda Accord LX 2.2 4 cylinder VTEC
Old Jul 1, 2019 | 08:07 AM
Krsheffield's Avatar
Default 97 Honda Accord LX 2.2 4 cylinder VTEC
I have no spark in my plugs, but everything checks out all the way up to the distributor. Had put new plugs, wires, cap, distributor rotor, Ignition coil, everything still no spark. Started with a bad downstream O2 sensor that I replaced, now it won’t fire. Last time I drove it, it backfired a couple times and shut off, hasn’t started since. Timing belt is ok as the distributor rotor turn while cranking. Have no idea what it could be please help me!!
Old Jul 1, 2019 | 08:38 AM
Just tested to see if I had any shorts in the wiring, there are none.
Old Jul 1, 2019 | 09:46 AM
Are you getting a check-engine light? If so, have a car-parts-store read the error codes.
Old Jul 1, 2019 | 01:01 PM
No code no check engine light
Old Jul 1, 2019 | 07:56 PM
hondaslave1342's Avatar
What about a ground issue..
Old Jul 1, 2019 | 08:13 PM
I’ve checked every ground I know of. Is there one I’m missing somewhere?
Old Jul 2, 2019 | 07:21 PM
The main engine computer ground is on the driver's side of the upper intake manifold.
Can you tell us what tests you have done so far on the wiring?
Old Jul 3, 2019 | 07:48 PM
djkurious's Avatar
Definitely check the "G101" ground as mentioned previously.
Old Jul 4, 2019 | 10:34 AM
You've replaced a lot of parts, so there is always a risk that a new part was bad out of the box.
Here is a link on testing honda ignition system using a test light. The LX setup is a bit different, because the coil is outside of the distributor. You would have to back-probe the green wire to the coil connector to test for the igniter switching to ground.
Krsheffield
Jul 17, 2019 09:59 AM
Chris Jameson
Feb 19, 2013 06:39 AM
navdeep
Apr 11, 2012 04:22 PM
Brandy
Mar 24, 2012 11:45 PM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
