98 2.3l ULEV NEED HELP
Old Jul 29, 2018 | 04:52 PM
Mcarter89's Avatar
Default 98 2.3l ULEV NEED HELP
I have a 1998 accord ex 2.3l ULEV automatic transmission. I have to swap the motor and need to know if I can still use my computer or have to do anything with that also? Please help need this this to start. Have replaced the timing system, plugs, wires, main relay is good. I have fuel spark but reads low compression on all four cylinders.
Old Jul 29, 2018 | 06:12 PM
What compression numbers are you getting?
Are you pushing the gas pedal to the floor when you do your compression test?
Old Jul 29, 2018 | 06:45 PM
Mcarter89's Avatar
yes I am and still getting an even 60 lbs in all four did a wet test and only hit 80 in all four
Old Jul 30, 2018 | 10:10 PM
It is strange that you have low compression across the cylinders for no reason.
Timing was listed on the items you changed. Did you replace the timing belt, and why? Did you have this starting problem before you replaced these items?
Old Jul 31, 2018 | 09:03 AM
Mcarter89's Avatar
The guy said he started the car ran back inside to grab his things came back out and the car was not running no antifreeze on the ground and it would not start so when I got it I did The Replacements as listed and it's still reading the low compression so I'm almost to the point of just replacing the F23A4 motor that's in it and I'm wondering if I have to use the same type of motor or if I can use an F23A1 or an F23A5 if you had the answer to that question that be great I'd like to use the same computer and harness
Old Jul 31, 2018 | 06:55 PM
I would stick with the same exact motor to ensure you don't run into any issues.
Old Jul 31, 2018 | 08:44 PM
hondaslave1342's Avatar
I would check valve timing..if someone replaced the tb and it ran before..i would go over the timing belt install..
Old Aug 1, 2018 | 05:58 AM
I think the PCM and the car's wiring harness is very different for the ULEV engine. If you have to use an F23A1 you might be able to somewhat make it into a ULEV by taking the exhaust manifold & front O2 sensor, along with your ULEV engine wiring harness. I don't know what other sensors might have been different.
Old Aug 3, 2018 | 03:37 PM
The Toecutter's Avatar
You want to stay away from the F23A5 engine, because it doesn't have VTEC (also uses a different ECU). The F23A1 and A4 are very similar though, and will probably interchange the easiest.
My 99 Accord and my wife's 2000 Accord both are LEV cars, and have F23A1's in them. Like Jim pointed out above, I believe the main difference between ULEV and LEV is the exhaust manifold, down pipe, and catalytic converter. The rest is basically the same.
99accordf23a5
May 6, 2014 12:51 AM
jhillblessed
May 10, 2010 09:55 AM
Honda_JD
Oct 24, 2009 08:12 AM
chesswiz
Apr 6, 2007 03:08 PM
01Accord
Feb 6, 2007 11:37 AM
