98 4 speed can only shift 1st to 4th
Old Nov 10, 2017 | 10:37 PM
accordfan2's Avatar
Default 98 4 speed can only shift 1st to 4th
My friend is selling his 98 Accord for $500. It's in great shape inside and out with 140k on the motor. The problem is (from what he says) you have to start in first gear, get up to about 25mph and pop it in fourth (2nd and 3rd wont go in). He says he has been driving it this way for a few weeks and does not have the money to trouble shoot it (Parents gave him a car) much less have it fixed. My question is this, I know Accords reputation even though I never owned one so even if I have to throw a couple grand into it I think I would be getting a deal. Any ideas on what could be causing this problem and maybe a dollar amount to repair? Thank You guys ahead of time for any replies.
Old Nov 11, 2017 | 07:48 AM
Worst case, trans needs to be replaced, cost "X"?
There are a few other things that you should think about - timing belt is how old, are there other wear items that need to be checked/replaced?
Old Nov 11, 2017 | 07:50 AM
You will have to diagnose the problem to determine the repair. If you can read the codes from the PCM using a scanner you would have a better idea of the problem.
Worst case scenario is that you would have to replace the transmission.
Old Nov 13, 2017 | 06:46 AM
It would help to know if it's a 4-cyl or V-6. They are completely different from each other.
Old Nov 16, 2017 | 03:31 PM
The Toecutter's Avatar
Also, since his car is a 98, he would need to find a 98 or 99 trans. Honda in it's wisdom decided to change something in the AT from 99 to 2000. As a result, there's the 98-99 version, and the 00-02 version.
Note; I have no idea what changed between the years.
Old Nov 25, 2017 | 02:54 PM
2000LX2.3's Avatar
Consider a complete trans fluid exchange to see if that helps. Old fluid will cause shifting issues.
Mike Romley
Dec 22, 2016 06:29 PM
SanDiegoAccord90
Jan 17, 2014 12:26 AM
SanDiegoAccord90
Feb 15, 2010 01:32 PM
5ofspades
Jul 25, 2009 05:26 AM
HondaPhyco
Jan 10, 2009 12:09 PM
