98 and 99 Accord TCM! Where is it?
Old Feb 20, 2006 | 03:02 PM
shutupbiyaatch
Default 98 and 99 Accord TCM! Where is it?
Trying to locate the TCM for a 98 and 99 Accord???
Anyone know where I can find it?
Old Feb 20, 2006 | 04:31 PM
lightshow's Avatar
Default RE: 98 and 99 Accord TCM! Where is it?
yea its in the passenger side kick panel
Old Apr 11, 2007 | 10:55 PM
fiktion's Avatar
I know this thread is a year old, but could you be a little more specific on where the TCU/TCM is at? I pulled the kick panel off, and the ABS Controller was behind it, not the TCU. I've searched EVERYWHERE. Someone said under the dash behind the center console, nope, just the SRS Unit and the ECU. Behind the passenger kick panel, nope, just the ABS Controller. Little help.... Please?
Old Apr 12, 2007 | 03:03 AM
fiktion's Avatar
I also just read that on the Accords, the ECU and the TCU are integrated. Which of these urban legends are true? Where in the hell is this TCU?! [:@]
Old Apr 12, 2007 | 03:14 AM
deserthonda's Avatar
it is all 1 unit ecm/pcm.. it is located below the center dash, rt side of heater, in frt of the srs unit,, it has 3 gray and 1 blue connectors going to it
Old Apr 12, 2007 | 05:32 PM
fiktion's Avatar
Okay... Well, that I found, thank you for your response. By any chance, would me unplugging it for a second, then plugging it right back in cause my car to not start anymore? When I put everything back together (and reconnected my negative battery cable), I tried to start my car, and all it would do was turn over. I wasn't getting a spark. I'm pretty damn sure I plugged everything back in, but I am going to check again here in a second...
Old Apr 12, 2007 | 06:51 PM
fiktion's Avatar
Okay, got it to start. The first plug closest to the cabin was unplugged. Transmission's still messing up though, so that leads me to believe that my problem is not electrical, but mechanical. I was hoping it was going to be electrical since the engine light reading was "Torque converter clutch main circuit malfunction" - P0740
*sigh*
Look out wallet, you're fixing to be drained!
Old Feb 16, 2016 | 08:08 PM
Jccaldwell1904's Avatar
Default It's probably the tcc solenoid.
It's probably one of the solenoids more likely the tcc noid... I'm having same problem and am going to replace the tcc solenoid see if that helps also let me know so I know if it's the right direction to go in.
*sigh*
geliott
Dec 18, 2012 09:56 PM
atlsk8crewboi22
Sep 21, 2009 12:39 AM
Haze217
Mar 3, 2009 01:27 PM
wish234
Feb 23, 2009 04:29 PM
FELON
May 31, 2008 07:35 PM
