98 Accord 4 cyl throws code P1259?
Old Feb 14, 2012 | 11:54 AM
britcardoc's Avatar
Default 98 Accord 4 cyl throws code P1259?
1998 Accord 4 cyl had a pair of leaks from the Vtec solenoid. Took it off, replaced the two "O" rings from Honda. Now it throws code P1259 as soon as you clear it and before you start it.
Runs like it is in "get me home" mode. Runs OK until you get on it. Acts like it has a rev limiter.
Went through the Alldata tests and everything was good except for replacing the ECM.
Help!!!!!!!!!!!!!
Old Feb 14, 2012 | 04:52 PM
Oil level is fine......?
Old Feb 15, 2012 | 09:10 AM
britcardoc's Avatar
Yes, 1/16 inch over full.
Old Feb 15, 2012 | 09:38 AM
I would inspect the electrical connections of the vtec for bent pins, etc... Also check that you didn't damage or pinch the wiring when you had it taken apart.
Old Feb 15, 2012 | 06:22 PM
So there is continuity from the 1 pin and B12, but nothing from the 1 pin to body ground?
Tesla
Jun 2, 2014 02:50 PM
Tesla
Mar 19, 2012 06:00 AM
hondalawstudent
Jun 13, 2011 10:00 PM
Mack010
May 25, 2011 03:17 PM
billvaughn
Jun 1, 2008 07:57 PM
