98 accord clutch
Old Nov 27, 2008 | 07:37 AM
pdude's Avatar
Default 98 accord clutch
Ok, 98 accord LX, 256K, mine since new.
I'm not sure what the problem exactly is, but when I'm in first gear, from lets' say at a stop light, anytime I have my foot on the clutch pedal for a while, when I start releasing it happens really quick, I mean not even 1/2 inch, and the gear engages, the clutch pedal has no resistance after that, until it comes all the way out, and then it's back to normal... of course until the next stop light.
Any help would be greatly appreciated.
Old Nov 27, 2008 | 10:13 AM
Default RE: 98 accord clutch
Possible internal or external leak at master cylinder (MC) or slave allowing clutch to gradually engage w/ foot on pedal. Look for external leak at slave cylinder by squeezing boot and looking for fluid. Look around MC on inside and outside of firewall. If no external leaks observed and fluid level is good, the MC is bypassing fluid around piston, allowing clutch pressure to be lost.
Replace damaged part, bleed system, and you should have clutch action restored.
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
yamahonda06
Apr 5, 2006 12:45 PM
