98 Accord EX clock light is out. Checked fuse. What's next?
Old Feb 8, 2009 | 08:34 PM
foxylady23's Avatar
Default 98 Accord EX clock light is out. Checked fuse. What's next?
98 Accord EX clock light is out. I switched fuse with a light fuse and light worked fine. What would be the next thing to check? Thanks in advance?
Old Feb 22, 2009 | 07:45 AM
jgrover
I have a 99 Accord that had the same problem. You must remove the clock from the console and replace the incondesent light bulbs. They have a twist base on them. Twist the base to remove the bulb. Insert a new bulb with its own base and then reinstall the clock.
Old Feb 22, 2009 | 04:33 PM
finch13's Avatar
Pop the clock out and put in a new one. Our sponsor, TAS Auto, sells them for $1.50 and the dealer is a bit more.
http://www.tasauto.com/Product/Browse.aspx?d=1022&p=3
Old May 18, 2009 | 12:27 PM
foxylady23's Avatar
Sorry but I waited a few days and never got any replies, so I looked around and found another forum that someone posted pix on how to change the clock light. I hope this helps someone else. It was very easy to change once I saw this. http://www.driveaccord.net/forums/showthread.php?t=1240
rjaccord
Jun 17, 2017 12:07 PM
dunnskii
Jan 14, 2011 09:27 PM
09^CBP^6MT
Oct 13, 2009 09:14 AM
cooch_csg
Nov 25, 2008 10:04 AM
